mishdeme
#1 Posted : 17 years ago
mishdeme
I have a Kenmore Dryer purchased in 2005. The heat just quit working on it on Sunday. The machine operates but with no heat. I have read some of the posts as far as what to look for and check but am still totally lost. I have located the heating element and I think I have located the thermal cutoff and hi limit thermostat, but not sure where the thermal fuse is. How do I check these to make sure they are working? I am an EXTREME novice and this is the first dryer repair EVER attempted.
ripleys
#2 Posted : 17 years ago
ripleys
The dryer runs on 2 30amp fuses or breakers. One for the motor and one for the heat. First off locate house fuses or breakers and make sure "BOTH" fuses or breakers are good. Just because it runs doesn't mean that both fuses are good!! That's where I would start if I were a novice LOL.:cool:
mishdeme
#3 Posted : 17 years ago
mishdeme
can you help with how to check to see if the fuse is working?
mishdeme
#4 Posted : 17 years ago
mishdeme
Still having trouble. Suggestions on how to check the fuse?
Kenmore Dryer no heat (Dryer Repair)
by joshwlf 12 years ago
by MAXDB 13 years ago
kenmore dryer no heat (Dryer Repair)
by davidb876 14 years ago
Kenmore Dryer No Heat (Dryer Repair)
by c22jrc 15 years ago
