I recently bought a house with this U-line 7 1/2 CF bar frig that conked out immediately. A repairman thinks it is not cooling properly due to evaporator fan motor not working. It will cost $1500 to replace it so would like to know if there are any parts available and if anyone else has had this problem. I live in a humid climate which may contribute to it's demise. Thanks, N Miller
firstly if it is the evaporator fan motor , that part costs < $100 .. Uline is in Wisconsin. Call them up and find out if there is a factory service center around your area . Nothing on that refrige should cost 1500 for a repair ..
Just go to U-Line Service - Welcome to U-LINE Service or U-line and look up a local servicer closest to your zip code. Also, parts are available and affordable. 800-779-2547 is the number to the U-Line Customer Care Call Center, they are very helpful.
