nicpat
#1 Posted : Tuesday, January 22, 2008 3:10:35 PM(UTC)
nicpat
The door cover broke at the hinge. In order to fix it the door had to be disassembled. Unfortunately, I can't figure out how to reassemble the door mostly because of the door latch. It's a new machine and I can't find any info on the door assembly and the diagrams are most unhelpful. Any ideas would be most helpful.
kawfeeman
#2 Posted : Tuesday, January 22, 2008 8:21:20 PM(UTC)
kawfeeman
there are 8 phillips screws on either side and maybe a few on the bottom , remove screws replace cover and reassemble ...
