jeffh
#1 Posted : Tuesday, January 22, 2008 5:43:42 PM(UTC)
jeffh
Dryer completely dead. Will not start when timer button is pressed. Interior light does not come on. There is power to the outlet. The door switch clicks when pressed. The timer has been replaced within the last 3 months. What would be the next logical steps to take/parts to check? Thanks in advance for any help...
misterfixall
#2 Posted : Tuesday, January 22, 2008 6:14:23 PM(UTC)
misterfixall
are you sure you are getting 220 volts coming from recepticle ,are you getting line 1 to neutral,115 volts +line 2 to neutral .115 volts? was light in dryer working prior to failure of dryer?
jeffh
#3 Posted : Wednesday, January 23, 2008 11:25:00 AM(UTC)
jeffh
yep. I put a meter on the outlet and got 115V from line 1 to neutral and 115V from line 2 to neutral. light in dryer was working prior to failure. is there a fuse (thermal or otherwise) internal to this dryer that I should look for?
misterfixall
#4 Posted : Wednesday, January 23, 2008 11:36:32 AM(UTC)
misterfixall
there is a thermal fuse kit part# ap 415996
jeffh
#5 Posted : Thursday, January 24, 2008 1:52:01 PM(UTC)
jeffh
thanks. I'll check that next, if I can find where it is...
abbie
#6 Posted : Thursday, January 24, 2008 2:12:08 PM(UTC)
abbie
Check to see if the belt is broken being over 10 years old there a good chance that it is .Can you take the bottom panel of the dryer,if so you can see if it broken.Another thing is open the dryer door and turn the drum,if it turns easy then the belt is broken.
Guest (6)
Admiral Dryer Dead (Dryer Repair)
by cypherlock79 4/11/2011 6:30:16 AM(UTC)
Admiral Dryer DEAD No Start (Dryer Repair)
by Rattytattom 2/10/2010 4:02:06 PM(UTC)
Maytag Admiral Dryer Dead (Dryer Repair)
by Rfunaro 7/21/2009 12:26:58 PM(UTC)
