jjx2
#1 Posted : Tuesday, January 22, 2008 5:18:54 PM(UTC)
jjx2
My dishwasher has been leaving black specks on the items washed in there for the last few weeks. Other than that, the items are cleaned of all food particles. I am assuming that the door gasket/seal may be old, and possibly dry rotted, and that by replacing the door gasket, the problem will go away. I have 2 questions....one, has anyone ever had this problem and am I correct in my assumption above, and two, to replace the door gasket, is it just a compression fit into a fixed groove, or is some sort of adhesive needed? In other words, can I just pull out the old seal, clean the channel and insert a the new seal? Or will I need to put some sort of adhesive in the channel first? Any help would be greatly appreciated. I've never had to work on my dishwasher before.
tap50
#2 Posted : Saturday, January 26, 2008 9:21:57 AM(UTC)
tap50
I'm having the same issue with my dishwasher. Did you find out what was causing your black specks?
Please e-mail me if you've figured it out at taparent@verizon.net
Thanks,
-Todd
tarthur1@bellsouth.net
#3 Posted : Monday, March 17, 2008 9:02:01 AM(UTC)
Did you determine whre the black specks were coming from? I'm having the same problem. By gasket seems fine.
