dputtre
#1 Posted : Thursday, September 10, 2009 6:05:00 AM(UTC)
dputtre
Hello-
I'm having similar problem to Bill. Suds/water pour out from bottom. Dishwasher is not draining. This dishwasher is less than a year old. Not been at all happy with it. Please advise. Cannot afford a repair person or a new one.
#2 Posted : Friday, September 11, 2009 6:57:34 AM(UTC)
Replacement parts for WHIRLPOOL TUD6710SQ0 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/d...0Sheet%20-%208275137.pdf
Remove the kick plate and find out where the leak is coming from.
A flashlight and a small mirror can help here. It is nice if the mirror is on the end of a stick re: like the ones car mechanics use.
Note that often where it is dripping from is not where the leak is and the actual leak is higher up in the unit.
Could be a hose clamp has come loose.
If it is a seal or part that is leaking then it should be covered under warranty.
