BCB
#1 Posted : Tuesday, September 8, 2009 5:53:23 PM(UTC)
BCB
Ran two loads of laundry. The dryer stopped. Will not start. Light is on in the drum. Tested door switch, panel and all seem to have continuity. Belt is on and fits well. Checked breaker and it is not tripped. The dryer is old but I've been able to make repairs with your help. Could use your help again. Sincerely, Brad
Frank / APP Team
#2 Posted : Wednesday, September 9, 2009 7:50:49 AM(UTC)
Frank / APP Team
On the blower housing you should see a thermal fuse, if it reads open that will prohibit the unit from starting. If it is open, make sure to clean out all duct work and home venting. Overheating causes it to go bad.
Part number: AP3132867
BCB
#3 Posted : Thursday, September 10, 2009 6:27:59 PM(UTC)
BCB
Perfect. That was it. Had visions of a new motor or new machine. $10 part did the trick. Thank you so much.
Frank / APP Team
#4 Posted : Friday, September 11, 2009 3:49:46 AM(UTC)
Frank / APP Team
You are welcome. Glad you got it going!
