Brucefamily
#1 Posted : Thursday, September 10, 2009 4:04:12 PM(UTC)
Brucefamily
The refrigerator began leaking water onto the floor about a month ago. At about the same time, water began to show up in the drawers on the bottom where the vegies go. Can you tell me where the water is coming from?
Frank / APP Team
#2 Posted : Friday, September 11, 2009 5:46:27 AM(UTC)
Frank / APP Team
Sounds you like you have a clogged drain for the defrost water. You should see the drain tube on the back wall of the refrig, if you disconnect it and can force some air or water down it, it should blow out the obstruction for you. Using hot water and a turkey baster works pretty well.
