Dryer will heat for a short time and then stops heating. Drum continues to turn and the timer continues, but no heat.
One of the two coils on the gas valve maybe getting hot and dropping out turning off the gas to the burner.
Part Numbers: 694540 & 694539
I would just replace them both at the same time.
