Dryer takes way to long to dry, i have checked the vent and it is clear. I opened the door and started it up and noticed the heating eleament starts and gets red hot for about 15/20 sec. and goes out and does not go on again for a very long time. Any input would greatly be appreciated. thanks Confused.:confused: :confused: :(
Hi, You will need to take the back of the dryer apart and check the places I show in the diagram for lint. Dryer Diagram
Thank you for the response, i will check that out and let you know.
confused
I just want to thank you for the diagram, it was a little different then mine but i found it with no problem, guess what?? FULL of lint about 2 cups worth, so we pulled it all out put it back together and did a load and presto 1 cycle and the clothes were dry, it didnt take 3 or even 4 cycles.
THANKS AGAIN FOR THE INPUT, boy i sure love the net.:) :rolleyes: :cool: :D
That's great! Glad to hear you got it going. Thanks for the update..
