I have replaced the pump and cleaned out all the arms but no water comes out of the upper arms. the lower arm works fine and has good presure it seems. I have blocked the water for the lower arm and still no water to the upper arms. I don't know what might be causing the water not to come out above. Can anyone give me a clue as to what it can be? Thanks.:confused:
Originally Posted by: larry compton  I have replaced the pump and cleaned out all the arms but no water comes out of the upper arms. the lower arm works fine and has good presure it seems. I have blocked the water for the lower arm and still no water to the upper arms. I don't know what might be causing the water not to come out above. Can anyone give me a clue as to what it can be? Thanks.:confused: The machine not filling with enough water can cause the pump to not build enough pressure. Is the water level getting up to the heating element? From there, look for obstructions in the feed tube to the upper arm. Then it would be a matter of seeing if there is something wrong with the impeller on the wash pump.
