my Kenmore Super Capacity 3.5 won't spin. it works fine until it comes to the final spin and it just stops. there are no funny noises it just stops and beeps like it is all done but the clothes are wringing wet! what is wrong with it?
model # is: 417.44052400
serial# is: XC51303365
Manufacture date is: 3/05
Well, we can never tell you with 100% certainty what is wrong, but most like your motor control board will need to be replaced. Here is the part. Part number: AP3891780
Since it is a fairly expensive part and there is some risk it is not the problem, I would take off the lower panel of the machine and take out the tech notes which will take you through some troubleshooting. Hopefully this will allow you to gain greater confirmation on the problem. Good luck.
