ohara
#1 Posted : Sunday, September 6, 2009 5:00:42 PM(UTC)
ohara
Washer does not drain in spin cycle, washer does go through the spin cycles and turns off but does not drain. I checked for clogs in hoses they are clear, disconnected the pump ran seperate power and pump turned on, not sure what the problem is, The Timer?
Washers fills,ok during the wash and rinse cycle. Any help
magician59
#2 Posted : Monday, September 7, 2009 11:31:09 AM(UTC)
magician59
Did you test for power at the pump connection?
ohara
#3 Posted : Monday, September 7, 2009 6:07:31 PM(UTC)
ohara
yes checked power to the drain during drain cycle did not get powerto the pump
magician59
#4 Posted : Tuesday, September 8, 2009 4:02:48 AM(UTC)
magician59
The problem, then, is in the timer or control board.
ohara
#5 Posted : Tuesday, September 8, 2009 1:15:02 PM(UTC)
ohara
it was the timer
Guest (4)
