5 year old oven - I checked some biscuits this AM and the Heating element was on fire. I watched for a bit and the element was actually burning - as the hot spot moved up the element, I noticed it had cracked.
I found I can get a new one this site, but is this a simple replacement or should I hire it out? I have a friend who is a master electrician, perhaps he could help. But if it is some what simple, I'd rather do it myself. Can anyone give me direction?
un plug stove,remove two screws fastening element to body of stove in oven .gently pull element forward ,revealing wires connected to element,pull off spade connectors, reatach to new element ,replace the 2 screws, test it
Thanks, as soon as i get my paycheck I'll order the part and try it. It sounds very simple and really pretty much what I thought it would be. Part of the old element fell to the oven floor and melded to it as it cooled, any advice on that??
