Allen19
#1 Posted : Sunday, January 20, 2008 11:18:50 AM(UTC)
Allen19
The door buttons on the freezer will not work for the ice, water, or light. The fan in the back of the freezer tries to start sometimes and can't. When It tries to start, it will make clicks(click, click, click,....) I can see the fan jump a bit but will not start. I found that pushing the buttons on the door (that don't work) will make it start up and run??? Please let me know if you have any idea whats wrong. Thanks!
#2 Posted : Monday, January 21, 2008 8:53:53 AM(UTC)
Most likely the problem is a bad control board (on the back of the fridge).
Probably the evaporator fan motor has to replaced too (problems with evaporator fan motor could cause a damage to the main control board).
- The part number for the main control board is AP3950129
- The part number for the evaporator fan motor is AP3875639
Allen19
#3 Posted : Monday, January 21, 2008 1:28:11 PM(UTC)
Allen19
Thank You Gene, I'll give it a try.
#4 Posted : Tuesday, January 22, 2008 2:01:15 PM(UTC)
Keep me updated, please.
