tundraman79
#1 Posted : Saturday, September 5, 2009 5:29:47 PM(UTC)
tundraman79
today my washer washed my clothes for 2 hours! we left and came back and the timer hadn't moved......I figure the timer is bad, but anyone else have an opinion? The spin cycle works fine i spun all the water out and got clothes out. It didn't move off the spin cycle either when i turned the dial to it.....
The only other detail is that the basin was tipped to the right...but maybe just because the clothing was uneven....Any help appreciated!
sidfink43
#2 Posted : Monday, September 7, 2009 7:05:13 AM(UTC)
sidfink43
Sounds like the motor inside your timer has broken. Here is the replacement timer.
Part number: AP3604425
Before you order it I would check all of the connections and clean them with an electrical contact cleaner. You might get lucky
Good luck
Guest (4)
Whirlpool Top Load washing machine drains as it fills. (Washer Repair)
by blairde1 1/21/2011 6:28:23 PM(UTC)
