Hi I have a older Whilpool direct drive washer, not sure of the model I can not find it. It was not pumping out and found the drain hose kinked. It also has been leaving lots of lint in the clothes and just started to stain clothes with a blue color. I hope this goes away now that the drain hose is opened up. I can not find a lint filter in it. I pulled the agitator up and there was not one there. Any help on these problems would be great! Thanks Sewerrat
Almost all of these machines have automatic lint cleaners, so there is nothing to do there.,
I would recommend you put in a washing machine cleaner. There are several good products available, and you can get a good one on this site.
Good luck.
