Hi, I am looking to install a recently purchased Auger and agitator assembly ( http://www.appliancepartspros.c...8&diagram_id=1356649) for my Maytage SAV365ZAWW. I'm assuming I need to seperate the upper Auger from the lower part of the assembly to install it. Is this correct and if so, how do I get them apart? I don't want to try to force them apart if there is a screw or something holding them together. :) Thanks in advance for any assistance you can provide!
Originally Posted by: eliszt Hi, I am looking to install a recently purchased Auger and agitator assembly ( http://www.appliancepartspros.c...8&diagram_id=1356649) for my Maytage SAV365ZAWW. I'm assuming I need to seperate the upper Auger from the lower part of the assembly to install it. Is this correct and if so, how do I get them apart? I don't want to try to force them apart if there is a screw or something holding them together. :) Thanks in advance for any assistance you can provide! You'll need to pop off the rinse aid dispenser from the top of the agitator and underneath that you'll see the bolt head that holds the agitator in place. Take a look at the parts breakdown(8) picture using the below link and you'll see what you're up against. Model SAV365ZAWW
My unit not only has a broken fin, but it also comes apart in two locations. So what I'm hearing here is the is that the part (#2 in the diagram) does not come apart and that to install it, I would just use a ratchet with a long extension. Correct?
Thanks again for all your help with this!
Originally Posted by: eliszt My unit not only has a broken fin, but it also comes apart in two locations. So what I'm hearing here is the is that the part (#2 in the diagram) does not come apart and that to install it, I would just use a ratchet with a long extension. Correct?
Thanks again for all your help with this! Yes sir. If memory serves me right it's a 9/19 socket, maybe 1/2".
Thanks! It's installed and working great. :-)
Originally Posted by: eliszt Thanks! It's installed and working great. :-) You're welcome, glad it's fixed and working.
