pete washo
#1 Posted : Monday, January 21, 2008 6:47:50 AM(UTC)
pete washo
Quick rinse light blinks, and somtimes the pots&pans light blinks,somtimes two lights blink. I've replaced the thermostat,the electronic circut board and checked the door switch,and thermal fuse. All OK. Could it be the front button panel? All the buttons feel ok. If i mess with it (open & close the door) I can get it to run but it does'n complete cycle. It mostly doesn't run at all. PLEASE HELP.
#2 Posted : Monday, January 21, 2008 3:45:21 PM(UTC)
The control board senses one or more pads on the key pad stuck, causing the lights to blink.
In order to provide the right part number for the console I need the color of the dishwasher.
pete washo
#3 Posted : Tuesday, January 22, 2008 6:45:04 AM(UTC)
pete washo
Thanks Gene, the color is Black. But is there any way to test the control panal first? I've already bought a not needed circut board. The press buttons all feel fine to the touch.
#4 Posted : Wednesday, January 23, 2008 11:52:37 AM(UTC)
The control board self diagnosed the problem and it is the key pad.
- The part number for the black console assembly is AP3097136
