captuper
#1 Posted : Monday, January 21, 2008 6:45:14 AM(UTC)
captuper
I USED MY OVEN YESTERDAY AND IT WORKED FINE. AFTER USING IT, I TURNED IT OFF AND WENT ON MY MERRY WAY. LATER LAST EVENING I WENT BY THE OVEN AND FELT HEAT FROM IT, AND WHEN I OPENED THE DOOR THE OVEN WAS HOT. THE ELEMENT ON THE BOTTOM WAS GLOWING IN TWO SPOTS (APPARENTLY CRACKED), BUT THE OVEN WAS SHUT OFF!!! I HAD TO TURN OFF THE BREAKER TO SHUT IT DOWN. AFTER IT COOLED, I SEPERATED THE CRACKED ELEMENT AND TURNED THE BREAKER BACK ON FIGURING WITH A BREAK IN THE CIRCUIT, IT WOULD NO LONGER HEAT. WRONG!!!!! WHEN I OPENED THE OVEN DOOR TO CHECK IT, THERE WAS STILL A SPOT GLOWING ON THE ELEMENT. ?????
I HAVE ORDERED A NEW ELEMENT FOR THE OVEN, BUT AM WONDERING WHY IT WAS STILL HEATING AFTER THE OVEN KNOB WAS TURNED TO OFF??
ANYONE HELP???
#2 Posted : Monday, January 21, 2008 3:40:11 PM(UTC)
Most likely the problem caused by the shorted control board.
In order to provide the right part number for the control board I need the complete model number of the unit. The model number you posted is incomplete.
