cookie87
#1 Posted : Friday, September 4, 2009 10:41:54 AM(UTC)
cookie87
The seal on my top freezer Maytag fridge was never quite right, leading to ice build up in the freezer. Finally, past warranty, decide to try replacing it. Ordered part from this site and received today - hooray! BUT, I've tried several times to install, I've soaked it in hot water, tried the blow dryer, and still the seal has more gaps than the old one I'm replacing. Any ideas?
#2 Posted : Friday, September 4, 2009 12:24:22 PM(UTC)
cookie87
#3 Posted : Friday, September 4, 2009 12:43:19 PM(UTC)
cookie87
Thanks, Gene. I'm going to try the oven: any idea how long? The blow dryer didn't work, nor did hot water (as suggested on the box). The problem isn't with gasket fitting into the groove, but with lack of a tight seal between the door jamb and the seal itself.
#4 Posted : Friday, September 4, 2009 12:48:02 PM(UTC)
Quote:
... I'm going to try the oven: any idea how long?...
I never did it myself.
Quote:
...The problem isn't with gasket fitting into the groove, but with lack of a tight seal between the door jamb and the seal itself...
I believe a duct tape should work.
cookie87
#5 Posted : Friday, September 4, 2009 12:56:29 PM(UTC)
cookie87
Okay, the over was a disaster area. Wrecked the new gasket in no time. Back to square one.
