slkcd@suddenlink.net
#1 Posted : Sunday, January 20, 2008 1:45:22 PM(UTC)
Bake element went out and we replaced it. After eveything was plugged in, I turned the oven on and waited for it to heat. The oven light indicator did not come on and the oven did not start to heat. Unplugged from wall and checked all connections. Everything was connected properly,but the oven still does not come on. Is there a reset button that needs to be pushed?
#2 Posted : Monday, January 21, 2008 9:46:28 AM(UTC)
Remove one of the wires from the bake element and check for 120V between each of the wire and the ground.
Post the results.
Also I need the manufacturing number (starts with the letter "P").
