tarbarr
#1 Posted : Tuesday, September 1, 2009 8:34:00 AM(UTC)
tarbarr
My Cabrio keeps having a dU code and the autolock clicks. It even does it for a short while after being unpluged. What is it and what needs to be repaired? thank you
sidfink43
#2 Posted : Wednesday, September 2, 2009 11:56:52 AM(UTC)
sidfink43
Most likely the door lock assembly will have to be replaced, but take a look at the trouble shooting methods in the service manual and see if you can get more confirmation.
https://secured.whirlpoo...73421b/$FILE/8178583.pdf
tarbarr
#3 Posted : Friday, September 4, 2009 5:57:42 PM(UTC)
tarbarr
It does not have to turned on. I have not done a load of wash in 3 days and tonight it started beeping and showing the dU error again. Is there some known issue with this problem?
king4022
#4 Posted : Tuesday, September 22, 2009 11:30:45 AM(UTC)
king4022
I just called and my washer was purchased in April 07 and they are sending someone to service it free of charge. Here is the number I called:
1-866-698-2538 .....I had not registered it and was able to do so when I called. Good Luck!
