Stove is an 06-07? model, but only used for a short time- house wasnt done. moved and olny have access to LP. Stove set up for NG. Dacor not the least bit helpful. Saw post regarding changing orafices stc and need valves also. IS THAT DOABLE? would I be able to get valves for the burners? are the LP/NG parts interchangeable so that I could change the orafices etc. I want to be sure ALL of the features work the way they should. Urgent and your assistance is much appreciated.
I am not familiar with Dacor but all the ranges I deal with come with the orifice kit and instructions on how to convert the gas valves. Look on the back and behind the storage drawer (if it has one). Most of the time you have to change the orifices on the surface units and adjust the orifices on the oven valves and convert the regulator. I don’t know exactly how to do it on Dacor but as I said you should have instructions somewhere on the stove or owners manual maybe. Sorry if this doesn’t help but it is all I have to offer. Range Repair Guide
i have same problem. Did you find a fix for your Dacor to convert it to LP? I'm next to hopeless but giving it one last try.
In order to convert the range to LP you have to replace the manifold with the gas valves and the pressure regulator. - The manifold assembly Part number: AP3887728
I have the exact same issue with a Dacor ERDE48 going from NG to LP.
Did anyone have success with this?
