Suspect control Panel on front of icemaker/water dispenser is faulty. When touchpad is pushed to select ice/water...green indicator light goes on/off but will not dispense either ice or water
Originally Posted by: savery Suspect control Panel on front of icemaker/water dispenser is faulty. When touchpad is pushed to select ice/water...green indicator light goes on/off but will not dispense either ice or water Problem presently is intermittent
I'm having the same issue, except I'm not seeing any lights. Is it the control panel bad?
GE Refrig Part # PSS26MGPA
I have ordered the control panel and will see what happens
changing control panel did not help.....any ideas from anyone?????
