4 Pages<1234>
chris14
#21 Posted : Thursday, August 13, 2009 6:26:51 AM(UTC)
chris14
Gene,
Installed new erc and everything is fine. Looks like it was both the faulty erc and the cracked keypad.Original sercvice guy was going to order the relay board, glad I did it myself, thanks for your help.
#22 Posted : Thursday, August 13, 2009 2:33:27 PM(UTC)
You are welcome. Glad to hear it. Thank you for the feedback and good luck with your oven.
tommagner
#23 Posted : Monday, August 24, 2009 3:55:32 PM(UTC)
tommagner
The clock displays OK. If I press any oven mode, Bake, Convection, etc. then I set the temp, I hear clicking and the display says pre-bake on with bake flashing, but then the oven turns off after about 10 seconds.
Model - AOCS3040WW
MFG - P1132348NWW
This sounds similar to the problem above but I'd like some advice from the expert.
Thanks.
chris14
#24 Posted : Friday, August 28, 2009 7:11:55 AM(UTC)
chris14
If you turn off power supply (at breaker) and the power back up do you get any error codes....may have to wait a few minutes before code comes up.
tommagner
#25 Posted : Friday, August 28, 2009 5:42:26 PM(UTC)
tommagner
The oven over the years has occasionally got the F1 code but it comes and goes. During this last problem, it got an F1 briefly.
#26 Posted : Friday, August 28, 2009 10:41:48 PM(UTC)
Most likely the problem is a bad Electronic Range Control.
- The ERC Part number: AP4040447
tommagner
#27 Posted : Saturday, August 29, 2009 6:01:19 AM(UTC)
tommagner
Thanks very, I'll order one and give it a try....Tom
dirtmover
#28 Posted : Saturday, August 29, 2009 8:59:32 AM(UTC)
dirtmover
I've got the exact same problem so would like to know how you make out. Mine has been doing this on and off for about 4 years but only during the summer, only shuts off while it's hot and I can usually get it going again after about 5 minutes of trying.
tommagner
#29 Posted : Tuesday, September 1, 2009 4:46:48 PM(UTC)
tommagner
My ECR will be delivered tomorrw, I'll post to let you know how it works. I won't get to it until after 6:00 PM EST but if all goes well and it's not too late I'll post the result...Tom
tommagner
#30 Posted : Wednesday, September 2, 2009 2:49:48 PM(UTC)
tommagner
I installed the new ECR today and the oven works great. 8 screws and 3 wire connectors is all it takes. Thanks for all the help, great diagnostic job....Tom
Guest (7)
4 Pages<1234>
