ChrisMNS.Ut
#1 Posted : Monday, August 24, 2009 9:02:02 AM(UTC)
ChrisMNS.Ut
I am not getting water to the ice maker or water dispenser. The farthest water goes is to the saddle connection right before the water valve. I took out the water valve and it seems clogged.
Can a water valve go bad? or can it be cleaned?
There are 2 electrical connections/or fuses[green] and [yellow] on top of the valve, are these needing replacement?
My regards.
#2 Posted : Monday, August 24, 2009 11:50:43 AM(UTC)
Quote:
...Can a water valve go bad?...
Yes, it can and it is very common problem.
Quote:
...can it be cleaned?...
I do not trust in it. The best solution is to replace the water valve.
- The water valve Part number: AP2115312
ChrisMNS.Ut
#3 Posted : Thursday, August 27, 2009 6:46:55 AM(UTC)
ChrisMNS.Ut
Hi Gene or qualified APP Volunteer Expert, thanks for the info. I have ordered the part from APP and installed it. Great! The water dispenser works again! But the ice maker doesn't still. Hasn't ever worked(since purchasing the home a year ago).
I removed the ice maker, cleaned it and inspected it.
The IM looks fine now but doesn't seem to get any power.
Also, the water disp. originally stopped working when I was filling up a 5 gal jug. Is this not advised?(Running the disp for like 10 mins straight?) I would think thats what made my previous water valve go out.
Chris
#4 Posted : Thursday, August 27, 2009 8:30:20 PM(UTC)
Quote:
...The IM looks fine now but doesn't seem to get any power...
Chis,
How did you check it?
ChrisMNS.Ut
#5 Posted : Thursday, August 27, 2009 10:54:26 PM(UTC)
ChrisMNS.Ut
I removed the cover and user a flat head screwdriver to advance the IM to just after the wire lever falls(that monitors ice level).
And added water by hand. It does nothing. I don't have a voltage meter but I did use a tic tracer and it responded that the cord that plugs into the IM is powered.
#6 Posted : Friday, August 28, 2009 11:08:50 PM(UTC)
It is very important to find out if the problem is inside the ice maker or outside and you have to have a simple multimeter in order to do it.
ChrisMNS.Ut
#7 Posted : Friday, August 28, 2009 11:44:16 PM(UTC)
ChrisMNS.Ut
Hi Gene,
I just went ahead and ordered a complete ice maker from here at APP. I am pretty sure it just needs to be replaced its about 10 years old and it was only 80$ here.
It should arrive next Wednesday and Ill see what happens when I install it.
Chris
Guest (4)
