My whirlpool dryer went out a few days ago.It had a burning smell like electrical and rubber together. I replaced the dryer cycling t-stat and the t-stat hi limit but they didnt work. The dryer goes on for a few seconds, makes a loud noise then clicks off. I cant find where the burning smell is coming from. Also i noticed the fan turns very slowly when it does come on.can anybody help?
Rank:: Advanced Member
Most likely the problem is the shorted motor. - The part number for the motor is AP3094245 - Here are the break down diagrams for the Whirlpool dryer Model LGR7646EQ2Good luck. Gene.
The belt on my dryer broke. Are all Whirlpool dryer belts the same? I looked for a model # on the dryer, but nothing. Also, how do you get the belt back on? How do I get it around the drum. Thanks
In order to provide the most accurate advise I need the complete model number of the dryer. You can find it on the door frame.
Post it as a new thread, please.
