AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Installing a beering kit in a westinghouse dryer
I am just curious on how hard is it to install a beering kit in this model? And if there are any instructions that I could look at. I am purchasing the beering kit through you all. Thank you for your time.
It is not a difficult job
Release the clips that hold the top to the front panel by inserting a screw driver or putty knife in the gap between the front and the top at the edges. The top will flip up. You can now take out the screws that hold the front panel, release the belt from the service panel in the back and the drum will come out.
You will now see how the rear bearing parts are installed, and just replace them like they were before.
Good luck.
Dryer Repair
