randy neel
#1 Posted : Wednesday, August 26, 2009 6:48:50 AM(UTC)
randy neel
Washer drains and starts to spin then stops spinning but continues thru cycle
sidfink43
#2 Posted : Thursday, August 27, 2009 12:51:05 PM(UTC)
sidfink43
Wow, interesting problem.
I would take off the front and disconnect the wire harness from the motor. I would then you contact cleaner to clean the connection of the wire harness to the motor. I have had several GE's in recent weeks that just had bad motor/wiring connections.
Try this, and if that does not work post back, but I have to tell you, I don't have a good recommendation after this.
GE Washer Stops Spinning (Washer Repair)
by newbiewasherguy 1/30/2014 4:16:17 AM(UTC)
