2 Pages<12
driz
#11 Posted : Tuesday, August 25, 2009 2:49:05 AM(UTC)
driz
It behaves exactly the same way
Ok so for my head can you clarify a couple things.
Does this washer pump out the water before it spins? I think not if memory serves.
Is this a slip belt type machine since it's only one speed?
I will figure this out yet........................:mad: :mad: :mad:
#12 Posted : Tuesday, August 25, 2009 4:56:33 AM(UTC)
I think this washer has a plastic tub, if so shine a light in the spin basket and look for something jammed in there.
driz
#13 Posted : Tuesday, August 25, 2009 5:33:01 AM(UTC)
driz
Everything on that one is metal and its not more than 5 years old. I replaced it with a good used one when the POS ate the sealing ring off of it. I never saw anything like it and neither had the dealer.
#14 Posted : Tuesday, August 25, 2009 12:07:50 PM(UTC)
Pull the top off the tub and look for something jammed in there.
driz
#15 Posted : Thursday, September 3, 2009 5:34:28 AM(UTC)
driz
Got tired of fixin the thing and gave it the deep 6. We got a new Roper at Lowes on sale for $300 and I have already stripped half of it for steel to use in welding projects. So I guess the old pig will live on in another form some way..............:D:D:D
Frank / APP Team
#16 Posted : Thursday, September 3, 2009 5:56:34 AM(UTC)
Frank / APP Team
Originally Posted by: richappy Go to Quoted Post
That switch is probably not available new, you saved at least $25 if it was.
Probably a little late now, but here's my two cents. Hopefully the motor carriage wasn't rusted and the motor glides were properly lubed and the springs were doing their job. If the mechanism wasn't floating like it should, it will sure cause a motor to overheat.
Many Maytag motors have been changed over the yrs due to nothing more then a spring and roller kit being bad.
Guest (7)
2 Pages<12
