AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool dryer-high pitch noise then shuts off
My dryer recently started to make a high pitch squeal when you turn it on and then after about 10 minutes automatically shuts off. Then when you open it smells like an electrical burn.
Originally Posted by: glb  My dryer recently started to make a high pitch squeal when you turn it on and then after about 10 minutes automatically shuts off. Then when you open it smells like an electrical burn. You'll need to remove the front panel and take a look at the motor and blower area. Make sure there isn't something in the blower. You can also try and tell if the odor is coming from the motor. If after it cools down it will than start back up it very well be the motor. If you provide a complete model # we can try and get you a parts breakdown for the unit.
Thank you for your quick response. I will get the model # tonight when I get home and reply back.
Dryer Repair
