thechief76
#1 Posted : Thursday, August 20, 2009 5:40:55 AM(UTC)
thechief76
My icemaker will only dispense crushed ice even when you push the cube button. Any help will be appreciated, thanks
#2 Posted : Thursday, August 20, 2009 3:27:38 PM(UTC)
Check the solenoid (#45 on the diagram) for continuity.
- The solenoid assembly Part number: AP3965560
thechief76
#3 Posted : Thursday, August 20, 2009 6:29:09 PM(UTC)
thechief76
thanks, now for a dumb question. How do you get the front panel off to get at the works, thanks again
#4 Posted : Thursday, August 20, 2009 8:29:20 PM(UTC)
Remove the ice bin and the screws secured the auger motor cover (#20). The solenoid is behind the cover. Possible the ice maker has to be removed as well.
thechief76
#5 Posted : Saturday, August 22, 2009 1:03:31 PM(UTC)
thechief76
Thanks Gene, ordered the part and will put in (attempt) next week, I'll let you know what happens, again thanks for responding, you guys that know this stuff and are willing to share are great.
Jeff
#6 Posted : Saturday, August 22, 2009 8:07:16 PM(UTC)
Jeff,
I did not say that the solenoid is 100% bad. I just do not know without proper testing. It could be something else wrong as well.
thechief76
#7 Posted : Saturday, August 22, 2009 9:48:59 PM(UTC)
thechief76
I know Gene, but I have to start somewhere, process of elimination. cant hurt , if I have to throw in a couple parts till I find it
Jeff
thechief76
#8 Posted : Tuesday, August 25, 2009 11:50:42 AM(UTC)
thechief76
Gene, put in new selonoid and it works beautifully, cant thank you enough for the help.:) :)
Jeff:)
#9 Posted : Thursday, August 27, 2009 8:55:52 PM(UTC)
Jeff,
I'm glad you hit bulls eye at the first try. Good job!
