need info on how to open dryer to find out whats making the dryer make rumbling sound on and during cycle . looked a view panel at belt and pullys, seem to be ok :rolleyes:
I think on this machine you remove the two screws on the bottom of the front panel and tilt it off. You can then take off the screws that hold the top and take it off.
A likely source of your problem is the drum rollers. You can get at them by removing the drum.
Good luck.
