a.faden@worldnet.att.net
#1 Posted : Wednesday, January 16, 2008 7:12:15 PM(UTC)
The baffles in my dryer have coins rattling around inside. I'd like to know how to remove the baffles to clean them out.
Thanks!
abbie
#2 Posted : Thursday, January 17, 2008 7:54:21 AM(UTC)
abbie
The first thing is to remove the lint filter,there will be two screws in this area,remove both screws.Then get a butter knife, and go to both top corners of the dryer,insert knife between the top section and the cabinet at each corner and pop the clips on each side.Tilt the top back and you will see the drum with the screws holding the baffle to the drum.Remove these screws....
