Just about 20min ago the back of my refrigerator started clicking over and over and hasn't stopped. there also seems to be a bubble sound when it clicks as though its trying to start something. The lights inside dim slightly on each click as well...
Help pls..
Thank you for your time.
Locate the main control board on the back of the refrigerator. check for 120 VAC at connector "J7-9" to terminal "J8". If there is proper voltage then replace the relay and overload at the compressor. If it would not help then the compressor itself has gone bad. In that case check the manufacturer warranty - it cab cover the compressor for up to 5 years. - The relay/overload Part number: AP3796033
Could the issue be with a defrost timer? if so... where is it?
I have read and was told that it could be and that i could locate it and give it a turn with a screw driver.
I have been looking for the thing for the whole day and i cant find it.. pls help.
Is this possible?
Thank you!
Quote:...Could the issue be with a defrost timer?... No, it has nothing to do with the defrost system. Quote:...if so... where is it?... There is no a such part in your refrigerator. The defrost cycle is operated by the main control board. Gene.
