txsugarbear
#1 Posted : Friday, August 21, 2009 11:56:03 AM(UTC)
txsugarbear
Our stove won't light. We checked the breakers and everything is fine. We turn all four knobs and we don't hear that click click click. We do smell the gas..so that is fine (I guess). Would the ignitor be bad on all four burners at once?? HELP:(
#2 Posted : Friday, August 21, 2009 3:21:56 PM(UTC)
If the oven works and the display is lit then the problem most likely is a bad spark module (#5 on the diagram).
- The spark module Part number: AP3031050
Because it's very expensive, you can use the spark module Part number: AP4010034
In that case you'll have to use the mounting bracket from the kit.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL SF325PEGN0 | AppliancePartsPros.com
txsugarbear
#3 Posted : Friday, August 21, 2009 3:34:15 PM(UTC)
txsugarbear
Thanks Gene!
I noticed the second part you listed says Maytag..it is ok to use on my Whirlpool? I sure like the lower price of 28.00 verus the 118.00!!!
I am still trying to find where/how to fix it on the diagrams...again thanks!!!!
#4 Posted : Friday, August 21, 2009 4:22:31 PM(UTC)
Maytag belongs to Whirlpool today.
txsugarbear
#5 Posted : Tuesday, September 1, 2009 3:29:03 PM(UTC)
txsugarbear
I asked you the other day about our burners not lighting...we didn't even think about checking the oven. We checked today before ordering any parts..the oven is not lighting and there is no pilot light. Is the oven on the same ignitor as the burners on our Whirlpool? thanks in advance
(hope you are NOT in harms way with the Cali fires!!!)
Model Number: SF325PEGNO Brand: Whirlpool Age: 5 - 10 years
#6 Posted : Wednesday, September 2, 2009 10:26:43 AM(UTC)
Originally Posted by: txsugarbear Go to Quoted Post
The oven igniter is absolutely separated from the top burners ignition. It's operated by the control board and has its own igniter (#16 on the diagram). In order to diagnose this problem you have to unplug the igniter and check for 120 VAC to the igniter while the control calls for Bake.
If there is proper voltage then the igniter is the culprit.
If there is no proper voltage then post the result and we'll proceed further.
- The oven igniter Part number: AP3135265
Guest (4)
