We have a problem where, even when the oven is not in use the display goes away and the oven will not work. It will come back on all by itself at any given time and the oven will work perfectly. I put it in the cleaning mode 20 mins ago and it is still on. Please help !!
Most likely the problem with you oven is a bad electronic oven control (aka EOC) which has to be replaced. - The part number fro the EOC is AP3672811 - The part number for the EOC overlay is AP3219801 Gene.
