I select bake, temperature displays 350 degrees (this is normal), press start temperature displays 100 degrees(Nothing happens). Select broil, igniter fires up, oven in broil mode. Help
Do you see the ignitor glow when "Bake" is selected?
No, the igniter does not glow when oven is selected, however, it does glow when broil is selected. If I wait until the oven is heated up, and switch to bake, everything works fine.???
Electronic touch pad, or dial control?
