slabman
#1 Posted : Thursday, August 20, 2009 5:39:35 AM(UTC)
slabman
Over the past several months BOTH sides have experienced periods of high temps-19 in freezer and 49 in fridge. After a couple hours, temps return to normal. Not I can't get temps back to a normal zero/38 degrees after re-cleaning the coil at bottom. The unit is in a built-in enclosure so I can't see the back and pulling it out requires door removal since there is an obstruction at the front. Last night and this AM temps are now 21/51 and it seems to be going bad fast.
Door seals are fine...fan at bottom coil runs....what to do?
slabman
#2 Posted : Thursday, August 20, 2009 6:19:08 AM(UTC)
slabman
Just turned the unit off for a half hour...temps still at 21/51... hoping they'll drop? After turning on the fans and compressor are still running. But what to do next?
#3 Posted : Thursday, August 20, 2009 3:37:15 PM(UTC)
Does the fan inside the freezer work properly?
I understand this is a huge headache, but the refrigerator should be somehow pulled out of the wall not only for condenser cleaning which is a part of regular maintenance. The most common problem with these GE refrigerators is a faulty main control board which is on the back as well.
Here are the breakdown diagrams and Replacement parts for GE PSI23NSTASV | AppliancePartsPros.com
slabman
#4 Posted : Friday, August 21, 2009 7:11:21 AM(UTC)
slabman
Thanks, Gene. I blew out the condenser coil yesterday and freezer dropped to zero overnight, but now it's climbing back up to 10 this AM. Not sure what's up now?
slabman
#5 Posted : Friday, August 21, 2009 11:59:32 AM(UTC)
slabman
Temps reached 20 again by noon today and are now going back down to about 8 degrees...still heading downward, I believe. Does this sound like a bad board?
#6 Posted : Friday, August 21, 2009 3:28:48 PM(UTC)
Do the fan next to the condenser and the fan inside the freezer work properly?
slabman
#7 Posted : Friday, August 21, 2009 4:21:59 PM(UTC)
slabman
Sure...no problem with those. Seems to put out a LOT of heat around the compressor, even after cleaning.
#8 Posted : Saturday, August 22, 2009 7:37:02 PM(UTC)
Remove the rear panel in the freezer and check how the evaporator is covered with snow. Normally it suppose to be 100% covered with thin snow. If it's not then it can be a problem with the sealed system. It could be low on Freon, a restriction somewhere or a bad compressor. If it's less than 5 years old then it could be under the warranty.
slabman
#9 Posted : Saturday, August 22, 2009 8:38:32 PM(UTC)
slabman
After pulling the unit out, I see there's no way for air to get in the rear grill next to the coil. I'm thinking I need to open up a hole in the enclosure box back there and get more air to that area.
