Tony A
#1 Posted : Wednesday, August 19, 2009 8:29:47 AM(UTC)
Tony A
Hello.. I have A Kenmore Series 90 Heavy Duty washer that won't agitate. I watch the timer move, but in the wash cycle it doesn't work. It will work in the spin cycle, and it will drain the water... Just no agitation. Please help...:confused:
#2 Posted : Wednesday, August 19, 2009 4:44:20 PM(UTC)
Does the motor run on agitation?
Tony A
#3 Posted : Thursday, August 20, 2009 7:51:01 AM(UTC)
Tony A
I can't tell.. It is quiet. The timer runs, and I see it going through the cycles. It gets to spin and it drains the water and spins. It just won't agitate. It is crazy. Thanks..
#4 Posted : Thursday, August 20, 2009 11:31:01 AM(UTC)
Remove the washer cabinet and check the wire harness to the motor and the motor itself. Inside the control panel you should find the tech sheet with the wiring diagram.
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 11 time(s).
Tony A
#5 Posted : Friday, August 21, 2009 2:32:39 PM(UTC)
Tony A
I checked the diagram and all wiring seems to match. I put it back together and then it still does the same thing. :confused: Do you think a switch somewhere may be bad??
KoKoMo
#6 Posted : Thursday, December 8, 2011 7:54:37 PM(UTC)
KoKoMo
this is the exact issue i am having with my machine kenmore 90 series 110.26901691.....my coupling is fine and so are my dogs please tell me what u did to resolve this issue.....and i noticed a small amount of oil under my machine if that helps any
#7 Posted : Friday, December 9, 2011 5:06:20 PM(UTC)
You may want to remove and visually check the timer contacts. Oil under the washer could be a sign of a bad transmission.
Kenmore washer series 90 spin problem (Washer Repair)
by Toby1 7/21/2011 11:52:50 AM(UTC)
