verhoff
#1 Posted : 16 years ago
verhoff
Just over a year old and out of warranty. We were using the convection part of the oven and the whole thing just died. Sounds like a common defect with the unit.
Regardless, upon inspecting it, we had a blown cavity TCO. Replaced it today and everything seems to be back to normal except for 1 thing. The Exhaust Fan keeps running. On the control I can turn it "on" and adjust it to high and low fan settings and it speeds up and down. But if I press to turn off the fan it still runs (at sub-low) speed.
The GE service manual says to replace the PCB but I think it's something else like a relay or some other part that got fried when the fuse blew. Any help would be greatly appreciated. Thanks.
#2 Posted : 16 years ago
This fan should run every time when the speed cook is in use. If it runs while everything is off then check a fan thermostat (somewhere on the bottom panel from inside of the microwave control compartment).
verhoff
#3 Posted : 16 years ago
verhoff
Would you be referring to what's on the service manual as a thermister? In the center of the picture. What I replaced was the cavity tco just to the left of it. Thanks again, Dennis
verhoff attached the following image(s):
#4 Posted : 16 years ago
No. It should be on the bottom, not on the top of the microwave because it senses the bottom panel temperature heated by a stove under the microwave.
ndgranderson@yahoo.com
#5 Posted : 7 years ago
Gene - we are having the same problem with the fan continuously running since we have replaced the Vent TCO & the Cavity TCO. Any suggestions?
GE Advantium 120
Model No. SCA 1000DBB03 Serial No. VF 900583K
#6 Posted : 7 years ago
You may want to start the troubleshooting from testing the base hood TCO (#1432 on the diagram) for continuity. It should read open while the microwave bottom is cold.
If it's closed. the part would need to be replaced.
The base hood TCO Part number: AP2023540
