My dryer makes an exceptional about of loud high pitch squeaking sounds. It still dries the clothes but is really loud. I took off the front panel and ran the dryer to try and locate the noise, but, it would not make the noise, so I gathering that it only makes the noise while loaded. Can anyone help me pinpoint where to look or where to go from here? Thank you
Originally Posted by: sassybutter My dryer makes an exceptional about of loud high pitch squeaking sounds. It still dries the clothes but is really loud. I took off the front panel and ran the dryer to try and locate the noise, but, it would not make the noise, so I gathering that it only makes the noise while loaded. Can anyone help me pinpoint where to look or where to go from here? Thank you The things I would look at are the two drum rollers, the idler pulley, which keeps tension on the belt and the glides that the front of the drum rides on. In order to get a good view you'll need to remove the front bulkhead, which is the next piece you're looking at once the front panel is removed. Below is a link to show you the items I'm referring too. Model MDE6000AYW
