dudley
#1 Posted : Sunday, August 16, 2009 2:31:09 PM(UTC)
dudley
During the rinse cycles the righrt and sometimes left bottom corner of the door leaks? Any ideas
sjwanderer
#2 Posted : Sunday, August 16, 2009 4:51:11 PM(UTC)
sjwanderer
Check the hinges to make sure they are not rusting out. Also check to make sure the latching mechanism is not loose. After that replace the seal, about $10 or so last time I saw it.
#3 Posted : Monday, August 17, 2009 4:43:28 PM(UTC)
Open the door during the rinse cycle and check if there are suds. Post the results.
Here are the breakdown diagrams and Replacement parts for GE GSD3900L00WW | AppliancePartsPros.com
