jobuck488
#1 Posted : Monday, August 17, 2009 10:29:44 AM(UTC)
jobuck488
I Have an error code f7,nothing but the clock works. Oven about 10 years old
#2 Posted : Monday, August 17, 2009 12:40:42 PM(UTC)
Most likely the problem is a stuck key on the key panel or a shorted control panel ribbon cable. The correction is to replace the control panel. If you need the correct part number then post the color of the control panel.
jobuck488
#3 Posted : Monday, August 17, 2009 3:31:29 PM(UTC)
jobuck488
The color is white
#4 Posted : Monday, August 17, 2009 5:57:03 PM(UTC)
The white control panel Part number: AP3155843
