2 Pages12>
boomerang6297
#1 Posted : Sunday, August 16, 2009 6:39:26 PM(UTC)
boomerang6297
dryer had been working fine today after several loads.now the dryer will not turn,but heats up.the drum spins freely by hand.when i hit the start button,i hear a click in the back.all lights on front panel seem to work as usual.any ideas?
kayakcrzy
#2 Posted : Monday, August 17, 2009 4:22:16 AM(UTC)
kayakcrzy
sounds like a broken belt, most likely because the idler pully disintegrated. i would buy the drive kit. it comes with 2 rollers and idler pully, and a belt. a cheap and easy repair. tom
boomerang6297
#3 Posted : Monday, August 17, 2009 6:14:30 AM(UTC)
boomerang6297
thanks,i will give that a try.
boomerang6297
#4 Posted : Monday, August 17, 2009 8:37:11 AM(UTC)
boomerang6297
i checked the belt,and it looks fine.while dismantling the dryer i found a diagnostic sheet.i ran a diagnostic on it and found one fault code.it says "INlet thermistor shorted".is this something that will cause my problem or do i have more than one problem?Thanks for any help:confused:
kayakcrzy
#5 Posted : Tuesday, August 18, 2009 3:10:43 AM(UTC)
kayakcrzy
You could have a thermister issue. But, Let me see if I understand you correct. when you turn the dryer on, the motor runs, but the drum does not turn, or is it dead. Tom www.applianceeducator.com:confused:
boomerang6297
#6 Posted : Tuesday, August 18, 2009 3:56:42 AM(UTC)
boomerang6297
thanks for the reply.the heat works,but the motor does not turn on.the belt is fine and the drum spins freely.the thermistor fault code was the only code that came up.i emailed the webmaster at the website that was in your last post.:confused:
kayakcrzy
#7 Posted : Tuesday, August 18, 2009 4:41:42 AM(UTC)
kayakcrzy
replace the thermister then. It is in the back and has two wires coming to it. Tom
kayakcrzy
#8 Posted : Wednesday, August 19, 2009 4:52:36 AM(UTC)
kayakcrzy
Jump out the thermal fix. It is # 48 on the bulkhead diagram, and see if it works. If so, do not run it that way. This is for testing only. Tom ApplianceEducator.com
boomerang6297
#9 Posted : Wednesday, August 19, 2009 11:04:28 AM(UTC)
boomerang6297
what does jump thermal fix mean.unplug the wires?in studying the spec sheet...this is the item that the fault code refers to.i took this part to a local parts supply and they said they do not stock this part because they do not go bad.a technician is coming tomorrow at 1pm.i guess i'll try to disconnect and run assuming that's what you meant.thanks for the help.:confused:
#10 Posted : Wednesday, August 19, 2009 1:30:23 PM(UTC)
Just to add my 2 cents...
The inlet thermistor is a part of the high limit thermostat assembly and there not suppose to be any heat at all if the thermistor is bad.
The major problem in my opinion is: the dryer heats up while the motor is not running. The cause of this problem could be: a bad (shorted) motor centrifugal switch or a heating element shorted to ground. It's easy to diagnose with a simple Ohmmeter.
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WED9200SQ0 | AppliancePartsPros.com
- The heating element Part number: AP3866035
- The motor Part number: AP3094233
- The thermistor Part number: AP3919451
2 Pages12>
