oerck157
#1 Posted : Sunday, August 16, 2009 8:14:40 AM(UTC)
oerck157
Below is orginal issue and did replace the water inlet valve with new one. This goes back to June 3 or 4th this year. Now it does the same thing is happening again but seems to be only on the heavy load only now any suggestions? I checked the conections and nothing has come loose on the part I installed. Technicain responded to original post on 6-2-2009 at 4:23pm
Original post below:
the model is a RCA this just started, when it fills the tank it keeps filling with water but after i get it to stop the rinse cycle runs fine. any suggestions what it might be and how to fix it?
thank you!
John Pat
fetgirlygirl
#2 Posted : Sunday, August 16, 2009 2:13:15 PM(UTC)
fetgirlygirl
I am having the same problem and had replaced the water level sensor. The water still wont shut off.
