Ken Smith
#1 Posted : Sunday, August 16, 2009 6:29:15 AM(UTC)
Ken Smith
My whirlpool washer does not drain before spin cycle I get water from the bottom all over the floor. Any suggestioins.
Thank You
sidfink43
#2 Posted : Monday, August 17, 2009 9:36:27 AM(UTC)
sidfink43
Hi Ken
Please post a full model number. I assume that the water on the floor is from it spinning with water in it and not a leak. Is that correct?
Also, have you check the drain and drain hoses to see that they are not obstructed?
Ken Smith
#3 Posted : Monday, August 17, 2009 10:03:12 AM(UTC)
Ken Smith
My model is SM 8280869 Whirlpool 5 cycles 4 speed combination, This started all at once never did this in the past. I have not checked the hose to see if it was obstructed. Thank you for the info, any thing else it might be.ThanksKen
sidfink43
#4 Posted : Monday, August 17, 2009 12:34:10 PM(UTC)
sidfink43
Hi Ken
Your model number does not come up, did you provide the serial number instead? Is this a U. S. model?
Let us know if you need more help, and if so, repost the model number is what you provided is not correct.
Ken Smith
#5 Posted : Monday, August 17, 2009 3:13:14 PM(UTC)
Ken Smith
That is all I have, I dont have a manual, the number I gave is the only number I could find. I look up & down I dont see no model #, where should I look else.
Thank you
Ken
sidfink43
#6 Posted : Monday, August 17, 2009 3:15:54 PM(UTC)
sidfink43
If this is a top loader, look on the rim after you lift the lid; if it is a front loader look inside the door.
