jaime
#1 Posted : Tuesday, January 15, 2008 4:10:31 AM(UTC)
jaime
i recently change the u-joint kit on it, but now shows on display ob that code is for off balance i redistribute the load i even took the load out but keep shows the same ob another thing the machine is not draining out if you can help me with same advice here i would aprecciated:confused:
#2 Posted : Tuesday, January 15, 2008 3:53:29 PM(UTC)
Most likely the problem is a clogged or broken drain pump.
There is a good possibilities that replacing the drain pump will fix an off balance problem too.
- The part number for the drain pump is AP3776224
jaime
#3 Posted : Monday, January 21, 2008 4:25:39 PM(UTC)
jaime
Ok... i just got the drain pump delivered, i put it on ; and everything is working perfectly thanks for your help.
#4 Posted : Tuesday, January 22, 2008 2:04:00 PM(UTC)
I'm glad you were able to fix it.
