How do I access the gas train assembly to install my LP kit? Does the dryer have to be taken apart? Does the front panel come off? Drum come out?
Yes, you do have to take the dryer apart in order to access the gas valve and burner assembly. Open the door and remove the screws holding the top panel through the door frame. Lift up the top panel and remove the four (2 on the top and 2 on the bottom) screws holding the front panel. The conversion kit comes with the installation instructions. - The conversion kit Part number: AP2044396
